Hmmm
Yeah, Iām stumped on this result too. I donāt understand.
This is element bindings play. @Daan was close with his suggested searches. This post and the AU session I linked likely contain everything you need to know about the topic.
Effectively if you havenāt cleared the bindings before moving to Dynamo player the binding behavior will persist. The easiest way to do this is to delete the bindings section of the DYN file in a text editor. Another option is to replace the nodes which make the Revit elements, then save without running the graph.
