Bulk replacing type parameter to instance (without clockwork)
This thread offered a solution to bulk replace instance parameters to type parameters with clockwork nodes : Bulk replacing type parameter to instance
Unfortunately, I cannot find these nodes on the new version of clockwork for the new dynamo. Is another solution available to bulk modify type to instance parameters in families??
Grateful for help!
Current Clockwork (2.6.0) package for Revit <= 2024 does have the node you are looking for.
There is also the OpenMEP package which has similar nodes used in the forum post
Make sure you also have DynamoIronPython2.7 - 2.5 installed
it should be there, do you have Bakery or other older package installed ? there gives conflict to clockwork package ??
