Error creating multiple floors in Python
Hello, I’m new to Python. I’m trying to create floors from a list of polygon lines, but I get this error on the curveArray adding to list:
Could I get some help? I’m using this code by now:
ArrayCurves = IN[0]
floorType = UnwrapElement(IN[1])
level = UnwrapElement(IN[2])
structural = IN[3]
curveList = []
out = []
for curve in ArrayCurves:
    curveArray = CurveArray()
    for c in curve:
        curveArray.Append(c.ToRevitType())
    curveList.Add(curveArray)
# Place your code below this line
for c in curveList:
        floor = Floor.Create(doc, c, floorType.Id, level.Id)
OUT = floor
Thank you!
hi
import sys
import System
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import Curve,CurveLoop,Floor,Transaction,Level,Line,XYZ
ArrayCurves=IN[0]
floortype=UnwrapElement(IN[1])
level=UnwrapElement(IN[2])
structural=IN[3]
revc=Autodesk.Revit.DB.Curve
outerCurv=List[revc]([c.ToRevitType() for c in ArrayCurves[1]])
innerCurv=List[revc]([c.ToRevitType() for c in ArrayCurves[0]])
outL=CurveLoop.Create(outerCurv)
innL=CurveLoop.Create(innerCurv)
listCL=List[CurveLoop]([outL,innL])
lslope=Line.CreateBound(XYZ(0,0,0),XYZ(1,0,0))
t=Transaction(doc,"Create a Floor")
t.Start()
floor=Floor.Create(doc,listCL,floortype.Id,level.Id,structural,lslope,0)
t.Commit()
OUT = type(outerCurv),type(outL),type(listCL),floor
cordially
christian.stan
Thank you for your quick answer!
Unless I’m wrong, doing those changes I get only 1 floor as a result. Unfortunately I need to proccess the list from python to create as many floors as polygons are in input[0]
Am I missing anything?
I thought you were trying to create the ground between these 2 curveloops as there is common matter between the 2 grounds it will generate warnings
what you are trying to do is achievable with the ootb node
if you make a for on the list this should create 2 floors
I’m writing this from phone so be careful
t.Start() floors=[] for c in listCL: f=Floor.Create(doc,c,floortype.Id,level.Id,structural,lslope,0) floors.append(f) t.Commit() OUT = floors
edit:
t.Start()
floors=[]
for c in listCL:
    f=Floor.Create(doc,List[CurveLoop]([c]),floortype.Id,level.Id,structural,lslope,0)
    floors.append(f)
t.Commit()
OUT = floors
You will get a warning like previously explained
if you validate you will have your 2 floors
Cordially
Christian.stan
Good morning, and thank you very much. You made my day with your help! Now it’s working as I was expecting to, and can continue.
Have a good day, and a happy new year!
Regards
Hi @jliebana , please mark Christians solution if it work for you so it probably could help other in the future…and happy newyear to you as well :wink: :wink:
