Create.NewFloor retruns Error curves do not form a closed loop
Goal
what I was trying to do is a floor via revit API but returns with an error :cry:
Backgorund
it is dynamo 2.0 in Revit 2019 no third pakages…
error
““Exception: The curves do not form a closed contiguous loop.
Parameter name: curves””
workflow
create 4 point > create 4 lines (to create a rectangle) > call Create.NewFloor (in the first argument, I have converted the revitgeometry )
could you please support me :slight_smile: or pointing to the correct documentation
Thank you
floors.dyn (33.6 KB)
# Enable Python support and load DesignScript library
clr.AddReference('RevitAPI')
crv = IN[0]
floortype = IN[1]
lvl = IN[2]
bol = IN[3]
cArr =CurveArray()
for i in crv:
	cArr.Append(i.ToRevitType())
newflroor = doc.Create.NewFloor(cArr,floortype,lvl,bol)
out = newflroor.ToDSType(True)
# Place your code below this line
OUT = 0
Hello and welcome :slightly_smiling_face:
A solution making a polycurve first
crv = PolyCurve.ByJoinedCurves(IN[0])
floortype = IN[1]
lvl = IN[2]
bol = IN[3]
cArr = CurveArray()
for i in crv.Curves():
OUT = out
Thank you… for that :slight_smile: I would like to ask you where and how did you find it?
Semantically speaking, that means that a list of the concatenated curves doesn’t mean a polycure… Well, good to know, thank you!!!
@g.claudio.scarafini
Creation.Document.NewFloor() method need consecutive curves (with the same direction)
PolyCurve.ByJoinedCurves() and polycurve.Curves() methods are perfect for this case
