Broken Nodes
Has anyone else run into this issue? It started a week or two ago. Whenever I open any dynamo script that is using nodes that get items, the nodes look like they have two inputs and outputs, but don’t work. I am not sure how to fix it. Any help would be much appreciated.
This is almost certainly a result of an add-in or other package loading a conflicting version of newtonsoftJSON. Check to see what packages, add-ins, and updates you have added/performed since the issue first presented.
That makes sense. I downloaded Orkestra to run Dynamo scripts more conveniently in Civil 3D, but that must be causing the issue. Is there a way to manage Orkestra loading this newtonsoftJSON for Dynamo? I would like to be able to continue to use Orkestra if possible.
You’ll have to manage that dependancy between Orkestra, your other add-ins, and Dynamo. Likely you’re on a conflicting version of Orkestra for your Civil 3D build. Start by updating C3D to the latest, and then updating Orkestra to the latest supported version for your Civil 3D build. Then reach out in the Orkestra forum that is linked 3x in your previous post and 4x in this one (gotta love auto links).
I will give that forum a try. Thank you for pointing out the issue for me.
