It seems I learned this the hard way: do not install any new update when things are already working.
Dynamo Python node is completely black.
Node to code is not working properly.
Edit 1: Python node
Which version and update is it ?
Dynamo Core : 4.2.2.6377
Dynamo Revit : 27.0.0.5893
Almost certainly a Revit add-in causing the conflict.
Disable all Revit add-ins (don’t just use the add-ins manager - things can still partially load there) and all Dynamo packages and customizations (easiest to rename the folder).
From there start Revit, launch Dynamo, and confirm things all work again.
If not, grab your Dynamo log and Revit journal, double check the journal to assure all 3rd party add-ins were disabled, and submit a ticket to support with the log and journal via the accounts portal at manage.autodesk.com.
If things did work after removing everything, close Revit, re-enable all your Dynamo packages, and confirm things still work.
If not, check the Dynamo log for which is causing the failure.
If things did work after adding the Dynamo packages back, enable your Revit add-ins, confirm the issue happens again, and check the journal for which add-ins are causing the error. Tags of api_error in the journal will bring your attention to where the issue is.
If there are no clues in the journal you can enable/disable add-ins using a binary search - halving the list every restart until you identify the culprit. With that method you can identify the offender among 64 add-ins in 6 restarts. Google binary search for instructions.
