This packedge use Dynamo Revit_2023 as plateform to integrating Revit_23, Civil3d_23 , Autocad, sofistik_2018, sofistik_2023 and Add extra geometry nodes to dynamo through API. It help bridge and tunnel engineers to create and Automate automate model and design.
Also makes it possible to create complex bridge and tunnel elements by using Adaptive family
HI @francois.picard
Can you try to download the package direct from dynamo pakedge website. Then copy it to the dynamo pakedge folder.
If v 4.0.0 working great
. You don’t need 4.0.1. 4.0.1 is the same 4.0.0 it only to solve conflict with other package
New release (V 5.0.0),
1- New Nodes are added to handle Excel
Not: I use ChatGPT
to write C# code for the below node (excel nodes)
ChatGPT
2- fix extract Reference from element
Now you can use this node to add Dimention
3- Send a Command to multi cad file
I have a recommend with name of node, better don’t use _ inside name of node. It is hard for user to search it.
Hi @chuongmep
I will change it in next version
. What i need to avoid the clacking with your pakege
@RMohareb it you mean is package conflict ?
@chuongmep
i rename my class to add “_” to avoid clash with your pakege. we use the same name of class. I thought your comment related to this conflict.
For the point name, yes i use _ in the name of point. i agree with you i will change it in next version
Like point cloud and list class
I think can keep with name no _ . DynaMEP is package long time no update, I will create a new fix for that
Update 20.04.2023
The New Package “BriMohareb_2024” now is available for revit 2024 and civil3d 2024
New Rev 5.0.3
Add Curve Class with two method
1-projectedPoint
2-ComputeClosestPoints
V530.dyn (22.1 KB)
Great work!
How is the compability between C3D2023 and your latest version?
Regards,
Patrick
Hi @patrick.ericson
The package access to civil 3d through com api.
The latest version is 5.0.3.
You can download the package 2023 or 2024 depending on the revit and civil 3d versions
New Rev 6.0.0 for Revit 2024
Add Bridge Class with two method
Very interesting videos
Is it possible to share dynamo examples in the vides?
BR
Sean
Hi @Xiaofei_Ying
1- make sure you have the latest version Rev 6.
2- make sure you open c3d file at the same time you run the script.
3- for simplified version i do not know if it different. Test first with the normal version c3d andif it work let me know and i will test with simplified version
Regards
Mohareb
- I have 2023 v6 and Revit 2023
- Any C3D file (even if it is empty) will work?
- It’s not simplified version of C3D, it’s simplified Chinese (Chinese language) version of C3D.
