1- great
2-the file which need to access also for empty files you can access to it
3-any language should be working. The c3d should be also 2023 and ti be c3d not Autocad.
Try to restart your pc and test.
1- great
BriMohareb_2023 compatible to run from dynamo revit not dynamo c3d
Run it from dynamo revit and at the same time you should open c3d file
I did run it from Revit Dynamo, not from C3D Dynamo.
I opened C3D before running Revit Dynamo.
@Xiaofei_Ying Are you can access to Autocad applications?
Yes, I have access to AutoCAD
“Topography between C3D and Revit with Dynamo” created by @sovitek . thanks Søren Villadsen ![]()
Hi Ramiz, thanks for sharing
and thanks for your awesome package
you are amazing
I’m always learning from you
Many thanks for your kind words
and right over ![]()
@RMohareb I have a project that is using Revit 2022 and Civ3D 2022. Will any of the BriMohareb_2023 versions/nodes work with 2022?
Download it from this link
Hi @RMohareb , thank you for this great package! I’m trying to get some points from a point cloud, what is the correct input for the solid?
@NikAl tje correct input dynamo solid and should be in cube or Cuboid shape.
so why i’m getting the error message? any ideas? thanks
Could you please send screen shots for the solid geometry
