I need your help.
This script is for converting AutoCAD line work into Revit.
Link a CAD file into your Revit model, then use “Select Model Element” to highlight it.
Plug in the family type you want to use (wide-flange beam for example) and the Level you want it on then run it.
I am still working on the same routine for vertical steel columns
CAD to Revit_Structural nodes.dyn (173.7 KB)
