Hi All,
Clear Contents node from BumbleBee package is saying ‘Success!’ but not modifying the file. Any ideas why?
-Revit version shouldn’t affect it?
-anything to do with file extension?
-not modifying the Excel file at all, so even if the worksheet name was wrong (it’s not), it wouldn’t matter.
Revit 2015 | Dynamo 1.2.1 | BumbleBee 2017.12.2 | Excel 2016
@Konrad_K_Sobon
Copyright© 2016, David Mans, Konrad Sobon
# @arch_laboratory, http://archi-lab.net, http://neoarchaic.net
import sys
import System
from System import Array
clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=11.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c')
from Microsoft.Office.Interop import Excel
System.Threading.Thread.CurrentThread.CurrentCulture = System.Globalization.CultureInfo("en-US")
from System.Runtime.InteropServices import Marshal
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
from os import path
assemblies = System.AppDomain.CurrentDomain.GetAssemblies()
path1 = [a.Location for a in assemblies if 'bbIcons,' in a.FullName][0]
path2 = System.IO.Path.GetDirectoryName(path1).rsplit('\\',1)[0]
bb_path = '%s\\extra\\' %path2
sys.path.append(bb_path)
import bumblebee as bb
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
filePath = IN[0]
runMe = IN[1]
sheetName = IN[2]
clearContent = IN[3]
clearFormat = IN[4]
cellRange = IN[5]
if filePath != None:
if filePath.GetType() == System.IO.FileInfo:
filePath = filePath.FullName
def SetUp(xlApp):
# supress updates and warning pop ups
xlApp.Visible = False
xlApp.DisplayAlerts = False
xlApp.ScreenUpdating = False
return xlApp
def LiveStream():
try:
xlApp = Marshal.GetActiveObject("Excel.Application")
xlApp.Visible = True
return xlApp
except:
return None
def ExitExcel(filePath, xlApp, wb, ws):
# clean up before exiting excel, if any COM object remains
# unreleased then excel crashes on open following time
def CleanUp(_list):
if isinstance(_list, list):
for i in _list:
Marshal.ReleaseComObject(i)
Marshal.ReleaseComObject(_list)
return None
wb.SaveAs(unicode(filePath))
xlApp.ActiveWorkbook.Close(False)
xlApp.ScreenUpdating = True
CleanUp([ws,wb,xlApp])
return None
def ClearExcel(ws, cellRange, clearContents, clearFormats):
# get origin and extent from range string
# if no range supplied apply formatting to entire sheet
if cellRange != None:
origin = ws.Cells(bb.xlRange(cellRange)[1], bb.xlRange(cellRange)[0])
extent = ws.Cells(bb.xlRange(cellRange)[3], bb.xlRange(cellRange)[2])
origin = ws.Cells(ws.UsedRange.Row, ws.UsedRange.Column)
extent = ws.Cells(ws.UsedRange.Rows(ws.UsedRange.Rows.Count).Row, ws.UsedRange.Columns(ws.UsedRange.Columns.Count).Column)
if clearContents:
ws.Range[origin, extent].ClearContents()
if clearFormats:
ws.Range[origin, extent].ClearFormats()
return ws
if runMe:
message = None
try:
errorReport = None
message = "Success!"
if filePath == None:
# run excel in a live mode
xlApp = LiveStream()
wb = xlApp.ActiveWorkbook
if sheetName == None:
ws = xlApp.ActiveSheet
ws = xlApp.Sheets(sheetName)
ClearExcel(ws, cellRange, clearContent, clearFormat)
try:
xlApp = SetUp(Excel.ApplicationClass())
if os.path.isfile(str(filePath)):
xlApp.Workbooks.open(str(filePath))
#Marshal.ReleaseComObject(extent)
#Marshal.ReleaseComObject(origin)
message = "Specified file doesn't exists."
except:
xlApp.Quit()
Marshal.ReleaseComObject(xlApp)
except:
# if error accurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
pass
errorReport = None
message = "Run Me is set to False. Please set \nto True if you wish to write data \nto Excel."
if errorReport == None:
OUT = OUT = '\n'.join('{:^35}'.format(s) for s in message.split('\n'))
OUT = errorReport
Okay so the node works when it’s using a live excel doc but not with a file path input
@Konrad_K_Sobon
What do you mean by “live excel doc”? How should the workflow look like?
When the file path is not connected (disconnect ‘file path’ to ‘clear contents’), it will use an open Excel workbook; make sure only one instance is open.
