Hii Everyone,
I’m just trying to create multiple shared parameters into family documents ,
i’ve used the DAN EDU pacakge and try Orchid Package , but nothing , anyone can help me ??
I’m using Dynamo 1.3.2 with Revit 2017
Hii Everyone,
Apologies I’m not at a PC, maybe this helps…?
Hey,
I suspect that you’ll want to run a graph just to close the family which is stuck open…
You’ll note that I have ‘data await’ which is the equivalent of ‘pass through’ before my close document… hopefully that fixes it?
Otherwise, if you upload a couple of test files we can have a look?
I think you’ll find the DanEdu package will just get more out of date, so I’d advise a strategy for replacing
Cheers,
Mark
where should i put the pass through node in my graph ?
What is the " Set Shared Parameter " Node function ?
the nodes that i used don’t open the shared parameter file itself so i think that im not in need if using passthrough
Hmm… but you are feeding the shared parameter file in? So it must be being read? Otherwise why feed it? If it’s being read you need to close it…?
is there any way to close it before saving my family documents ?
I think the Set Parameter Node was coded by Erik for this specific situation
it’s possible someone else has made an equivalent node, or you could have a dig around in the api to recreate it yourself?
This is the graph I have been using with much success from @Erfajo.
https://forum.dynamobim.com/t/add-shared-parameters-to-some-families-orchid-package/21254/13?u=scrowe
Thanks for your response but i have a problems with orchid Package Setting Up
Thanks A lot Mark.Ackerley , this is the reason for all issues, so i have made a workaround and use "Save As Document " Instead of Save and Close.
Now Every thing goes on the right way.
That’s really smart, great work!
Thanks A lot Mark
Hi, These two packages which version in Dynamo. I can installed but it got only ABOUT node nothing else. Will you help me out?
Can you please share the packages, it is not available in the package manager anymore.
Can you please look at the issue I am having. I can not solve this
