I got for one family the A parameter in Dimension (PG_GEOMETRY) as expected, but nothing about B parameter.
In the second family, I got The A & B parameters but in Others(INVALID), don’t know why.
In the other hand, If I look at the Shared Parameters txt, there is an A parameter in General as a Text and a B parameter in Dimensions as a Number as expected.
Mmmmmm, As I said, the shared parameter txt is clean, but when I run the script, dynamo create both parameters in the txt. That’s why I thought it wasn’t necessary
I think the way i’m creating the list for the parameters is the root of the issue, sometimes I made it works and sometimes don’t I need to check how sensitive is Dynamo if a Node Crash, because I noticed sometimes I need to close the software and open it again or even jump the node and plugin directly to the close node becuase the families are still open in background.
Would be really helpfull if the node crash or something else the node can close the families automatic
@erfajo lets say that i want two cases, add only one parameter to som families in a folder, path added in “directory path”, i have deleted the “brackets” and i have only add “a” and i still have the same warnings (picture attached)
@erfajo thanks for you help, but unfortunately i still have the same problem.
have you tried in your computer?
it is weird, but something is wrong and i dont know what
Hi Erik. Thank you for creating this routine and your Orchid nodes package. I was just wondering if the FamilyDocument.AddSharedParameter node could incorporate an Input using the same line of thought for the Tool Tips. We know that once a shared parameter is created, there is no way editing them to incorporate the Tool Tips. I know that in Revit 2018 when they are brought into a new project one can do it but not in the previous versions. Is that possible? Please! I thank you beforehand for your help and attention.
