I’ve downloaded the Bakery package and I put it in the package folder, but Dynamo doesn’t recognise the folder.
I opened one of the scripts of the package an then all the package appeared in the Dynamo’s tree but no one works at all. It is allways the same error:
Because of my company firewall, I can’t install directly the package from Dynamo, so I’ve download them and copied in the package folder. I deleted everything, uninstall and install Dynamo and just put the Bakery package and still doen’t work.
Hi Manel, I am the creator of Bakery. I haven’t had the crash problems you experience. I am using Dynamo 0.9.2, usually on Revit 2015. Bakery has a lot of dependency packages, as shown below. As a workaround, you can download my entire packages folder here for testing purposes.
I’ve downloaded your packages and put them into the package folder.
Sth strange happen in my Dynamo. e.g: If I copy your BlackBox folder, Eleemnt is hidden, element from & to IDs and Element in View to my flder, the rest of the packages don’t appear in the library of my Dynamo. If I delete them, the rest appear.
@Luke_Johnson hopefully you’d be able to help (or anyone else if you know) - I have tried to install Bakery without success. It was working fine before but I don’t know what’s the problem now. I have uninstalled all other packages and have restarted my PC several times before and after installing Bakery alone. It still won’t work…
When I install it, all I see is this:
Thank you @Alban_de_Chasteigner, I did that but I open and restart Dynamo again and still shows the same way (sorry I should have mentioned that I did that too)
