Background of Python Editor displays black color and not show anything
Hi all,
Like my title, anyone know the reason? thank so much.
Feels like a dependency conflict, perhaps AvalonEdit? A few troubleshooting steps:
  1. Restart your CPU, disable all Revit add-ins (including the pesky hard to find ones), launch Revit and see if the issue persists.
    • If that fixed the issue, re-enable add-ins in small groups until you find the conflict.
    • If the issue persists , proceed to step 2
  2. Shut down Revit, remove all packages in Dynamo (you can just rename the folder(s)) and restart Revit to see if the issue persists.
    • if that fixed the issue start adding the Package back in batches, restarting Revit between each batch.
    • if the issue persists still contact support directly via manage.autodesk.com.
Thanks so much,
Maybe my Dynamo conflicts to Speckle, I uninstalled it, and the Python Editor came back.
Make sure you’re using the latest version of speckle for your Revit release; If so likely best to submit an issue to them directly to see if we can sync up.
