Hi All,
Is there a way to convert revit family length unit from imperial to metric mm, area to sqm? Thanks.
Regards,
Dylan
Hi All,
Regards,
Dylan
Manage -> Project Units -> set as desired.
Revit converts automatically - no need to do any other conversion.
What you might want to do is change the default units of Dimension Types.
I don’t think you can access these part of Revit via Dynamo; these are more easily (for relative values of ‘easy’) set using the Revit API. try thebuildingcoder.typepad.com for further information about the Revit API
Hi Adrian,
thanks for your reply. I tried API just now it works. I have worked at BLP before. such a small world.
Regards,
Dylan
Well, it is in Australia!
can u pls share the script here it will be more useful
