You need a passthrough node like Jakob says, in a Codeblock or a Node.
But you might mark the solution for the topic and start a new topic for the other question :-).
Hi Jean
I installed Quasar package which includes ViewSelector and DeleteElement nodes. But it doesnât work for me.
Do you know where the problem is?
Thanx
@Mojtaba.vlj which dynamo version are you using?
These nodes working fine in both 1.3.x and 2.x.x versions.
Hi Jacob
Thank you so much for your response.
If you have, could you please give me a simple example of List.LastItem({WaitFor,PassThrough}); code block?
Thanx
Check out this post:
he says its deprecated
@Dimitar_Venkov he says its deprecated but does recommend another node tho
You should use the Passthrough
node from Clockwork:
