Autodesk.Revit.DB.Parameter to Revit.Elements.Parameter
How can I wrap DB.Parameter to Revit.Elements.Parmater?
Running this:
from Revit.Elements import ElementWrapper
parameter = IN[0]
OUT = Revit.Elements.ElementWrapper.ToDSType(parameter, True)
Causes this:
File "<string>", line 9, in <module>
TypeError: expected Element, got Parameter
did you find a solution? I am wanting to get the corresponding parameter ID of those parameter Elements but not the ID of the element parameter
I wish you good health. In the previous python node, you must perform an operation with the code that you wrote directly with the element itself, and then get its parameter. The value will be readable.
