how can retrieve the value of parameters by python. my code is below. Not sure what is wrong or missing.
clr.AddReference("RevitAPI")
#from Autodesk.Revit.DB import *
from Autodesk.Revit.DB import Mechanical
from Autodesk.Revit.DB.Mechanical import DuctInsulation
from Autodesk.Revit.DB.Mechanical import DuctShape
from Autodesk.Revit.DB.Mechanical import DuctSettings
from Autodesk.Revit.DB import Connector
app = uiapp.Application
el = UnwrapElement (IN[0])
cType =
shMlst =
shSlst =
co1List =
for cn in el:
con = cn.MEPModel.PartType
con = cn.Parameters
cType.append(con)
OUT = cType#,dir(cType[0])
