Element.pameter button code in python
Hi guys
I’m trying to mount simulate how it works element.parameter button, but there are some problems as follows:
python code:
clr.AddReference(“RevitAPI”)
import System
app = uiapp.Application
dataEnteringNode = IN
_e = IN[0]
elements =
for i in _e:
`elements.append(UnwrapElement(i))
def valuePara(_e):
a1=[i.Definition.Name for i in _e.Parameters]
a2=[i.AsValueString() for i in _e.Parameters]
_epara=
for i in range(len(a1)):
_epara.Add(str(a1[i]) + ': ’ + str(a2[i]))
return _epara
value =
for i in elements:
value.append(valuePara(i))
OUT = value
Hi @dangthanhnam01.kt199
Standard OOTB node will do the job.
Sorry for the late reply. Problem was solved :relaxed:
