I have a 3D Spline which is inside an AutoCAD DWG file. And I want to bring it into Revit Family instance by Dynamo.
Which nodes do I use to bring a curve inside a DWG into a Revit Generic Model Adaptive Family Editor, further to Create Solid Form Geometry?
Traditionally I could explode an Import instance but the only curves in XY plane gets created as model lines in Revit. Splines in XZ plane and 3D Splines disappear.
The related files are here which is an editable link where you can place any graphs or files that you might want to give me. ![]()
