Hi, I have started creating a graph for auto dimensioning all Mechanical Equipment’s on drawing. While running the graph I’m not getting dimensions on drawing. I’m not sure what wrong I’m doing can someone please suggest what is wrong in graph.
Dimension I’m looking for
So dimensioning is a bit awkward because References don’t have any geometry which we can view to see what is going on.
To create a dimension you need at least a pair of References… In your above example you will need a Reference from the Grid Line and a Reference from the family, perhaps the Center (Front/Back) Reference.
You also need a line to create the dimension on, so it must be parallel to ‘D’, depending on your family, this is not necessarily the case with the location line.
Your example will be further complicated because you need to create the correct list structure for Dynamo to understand what you want… So you will need sub lists per element… A sub-list with a line which corresponds to a sub-list of references.
I would have a search around in the forum and do some reading… Auto dimension MEP - #8 by Alban_de_Chasteigner
Then I would make a very basic example with only 1 dimension you are trying to create… Once that is working, I would increase the complexity.
If it isn’t working, I would probably try and create lines to visualise all the pieces you are trying to use when creating the dimension.
Hope that helps
Mark
Hi Mark,
Thank you for highlighting the point for dimensioning and providing the forum link for reference. I will try to implement your suggestions.
