Dear All,
I Want to create dynamo scripts for Blocks Auto fill to plan boundary with my conditions. Please advise. its possible or not?
Given Conditions
1)The block should be arranged inside the slab boundary and should not clash with the walls, columns,openings etc and not clash each other blocks
2)The block need to be arranged based with the larger size as priority and best fit orientation
3)The sample is attached with 5 standard blocks which is to be automatically arranged based on the economical condition of size and orientation
4)here provided Slab , opening,wall,beam column used in different layers in the floor plan.
Please find the attached file in Inputs and I’m arranged manually OUTPUT (this output i want automatically),
Thanks advance.
Sample1.dwg (1.8 MB)
