I developed a simple Python script for Dynamo/Revit, and it worked perfectly on my computer, as shown in the attached image.
However, when I copied the same routine to Dynamo on another computer, the following error message appeared:
For reference, here’s the code I used:
clr.AddReference('RevitAPI')
fc = BuiltInCategory.OST_Walls
allStructConnections = FilteredElementCollector(doc).OfCategory(fc)
elements = allStructConnections.ToElements()
OUT = elements
I’m not sure what caused the error, and it doesn’t seem to make sense, especially since the versions are identical: Revit 2023.1 and Dynamo 2.16, both on my computer and my colleague’s.
Has anyone encountered this issue before? Any ideas on how to resolve it?
Thanks in advance for your attention and help!
getElements.dyn (2.9 KB)
This looks like a conflict with another addin or library, maybe pyRevit?
Hello, thank you for your response!
I also suspect that this might be a library conflict, as you mentioned. However, I can confirm that we are not using pyRevit in this case.
Could you please suggest what other libraries or addins might be causing this issue? Are there any known conflicts we should check for?
Once again, thank you for your time and assistance—I truly appreciate your support!
I don’t know
By curiosity, this code works ?
import System
#fc = BuiltInCategory.OST_Walls
key_, values_ = System.Enum.GetNames(BuiltInCategory), System.Enum.GetValues(BuiltInCategory)
fc = System.Enum.Parse(BuiltInCategory, "OST_Walls")
OUT = fc, key_, values_
Hello, thank you for providing the new code!
We applied the code as instructed, but unfortunately, it didn’t resolve the issue. Instead, we encountered the error shown in the image I attached in the post.
Do you have any other suggestions or ideas about what might be causing this problem?
Try using the IronPython3 engine from the package manager (be sure to get the right version for your Dynamo release)… Sadly enums in CPython are dicey between builds.
I can’t say for sure, but I think the CPython3 engine doesn’t initialize correctly, try describing similar code using DyanmoSandBox 2.16, if you get the same error you may have a conflict with other software (I personally had a conflict with 3DS Max, which also uses Python).
For the production part, use IronPython2 or 3 in the meantime.
Note: if you can, it would be a good idea to test the latest PythonNet3 engine (Dynamo3.4-Revit 2025.4) to confirm whether the bug has been fixed.
Hello everyone!
I managed to work around the issue by updating Revit from 2023.1 to 2023.1.6 and Dynamo to 2.16.4. Additionally, we had to reset CPython in Dynamo. After performing these steps, the command started working again.
This update improved the execution of the commands, but new issues emerged—for example, the system fails to find the X-point value, even though this does not happen on another computer.
Given our tests, I believe there is some instability with CPython in Revit 2023, as we tested the same workflow in Revit 2024 and 2025, and the problem did not occur—at least so far.
Unfortunately, I reached this conclusion due to program instability, but I hope this issue does not persist in future versions.
I also want to express my sincere gratitude to the two contributors who helped me understand what was happening @c.poupin and @jacob.small.
Thank you very much!
