i’m mainly on C# and Revit, not expert on Python (yet) so pls forgive my naive questions, i encountered similar issues just recently that output from Python cannot be used in Dynamo input even though data type looks the same, see attached.
not like C#, seems Python lacks debugging method, i usually put any stuff in OUT for checking purpose which is not efficient at all, any tips in debugging?
thanks.
You’re feeding the node a Revit bounding box, whereas it expects a dynamo one. Even tho the two are semantically the same, they are entirely different object types.
Similarly, Dynamo’s all elements of categories node expects a “wrapped” category type
thanks KulKul for the tip, yet to figure out boundingbox issue and what’s wrong w/ ToDSType?
hi KulKul, do you know how to convert BuiltInCategory from Python to Dynamo i.e. “bics = System.Enum.GetValues(BuiltInCategory)” which has more categories than “cats = doc.Settings.Categories”, and i don’t quite understand yet, thanks
hi Dimitar, is there any documentation on (un)wrap stuff i.e. how to use ToDSType and ToRevitType? seems i still cannot figure out how to convert Python’s BoundingBox to Dynamo one, thanks.
Hi @Ning_Zhou.
Have a look at this:
https://github.com/DynamoDS/Dynamo/wiki/Python-0.6.3-to-0.7.x-Migration
thanks Martin for the link.
well, seems ToDSType not working for bounding box?
That’s because you’re calling Dynamo’s Revit Element wrapper method. If you are looking to return ProtoGeometry try ToProtoType() instead.
thanks Thomas, i tried ToProtoType(), same error message
You’re using wrong quotation marks
or at least the formatting is wrong on them
Look at line 23 and maybe others before that
great eye, thanks Jonathan!
