Assign All Linked Autocad File to Its Workset
hi all
i try to Assign All Linked Autocad File to Its Workset but i failed twice
please advice
Assign All Linked Autocad File to Its Workset.dyn (27.1 KB)
You need to get the workset as a element, then you put that into the value section of the last node.
i didn’t know how to get the workset as a element
Depending on how you link or import the DWG (Option “Current view only”), there is a workset for the instance and one for the type.
If the “Current View Only” option is checked, you can only set the workset of the DWG file type.
Instance :
Instance
Type :
same error Parameter is read only :frowning:
yes i imported it as (Current view only)
So your Importinstances don’t have a workset.
Replace Importinstance with CADLinkType in the Element Types node.
thanks @Alban_de_Chasteigner for your kindly response , you are amazing :slight_smile:
