I have a strange situation where summing area of rooms in Revit doesn’t give the same result as sum of area after unit conversion (which is a must if not using imperial, right?) in Dynamo. Any idea how to deal with this?
I want to keep metric units in my schedules. What do you mean I could change rounding in Dynamo? As you can see both set of values are rounded in the same way although giving different results.
Thank you - this worked.
