Dynamo for Civil 3D Pipe Network Swap Multi-PartS
Follow the YouTube channel, it perfectly aligns with what I want.
Use your Dynamo scripts to easily change the size of all pipes in a single pipe network system, it is single pipe size,
If we have a single pipe network system, referred to as “N0-D1”, which includes two or more pipe sizes, such as 100mm, 200mm and 300mm.
For example, one pipe in the network is 100mm, while another is 200mm and 300mm size.
Pipe 100mm (Pipe-1)
Pipe 200mm (Pipe-2)
Pipe 200mm (Pipe-3)
Pipe 300mm (Pipe-4)
Change (Pipe 200mm (Pipe-1,2,3)) to Pipe 300mm
Have any dynamo scripts can help to replace or change the pipe size mutiple pipe?? Thank you!
u can play with list nodes.
Code block won’t work input potions
Can the Dynamo function in Civil 3D use the ‘Select Objects’ feature to select multiple pipes for size modification and how to do it?
