Dear all,
I am working with a telecom network where need to model conduits which having different configurations like 3x110 dia pipes in top row then 3x 110mm pipes in bottom raw etc.
I am creating conduits from pressure network in civil 3d, and then copying manually as required to sideways and to bottom.
How dynamo can help me out to carry this more faster?
Also, is there is a dynamo available for swapping multiple pressure pipes?
Regards and many thanks
Hi
You can Using Pressure Pipe Runs
And see this
Hi, thanks for that… its almost there… copying is different from creating pipe runs.
regards
Ok
May this help you
Sinoj,
Did you find a solution yet/Do you have any examples .dwgs and any .dyn progress to share?
