Just wondering if the archilab view override nodes referenced in Konrads post below are still available in the archilab package?
I cant see these in dyn 2.0.1… latest archilab.
If there are ootb nodes available can someone please point me toward these?
I would like to set view transparency through dynamo. The nodes available seem to override elements but I’m keen to set graphic options for views.
Thanks.
I believe these were moved to the Dynamo For Revit core nodes. As Konrad pointed out in the post you linked.
Hi Jacob,
I can only find the node which overrides elements.
OverrideGraphicSettings.ByProperties
But I want to change the transparency of a view under:
Graphic Display Options
Model Display tab
Transparency
