Group Curves does not work anymore. When i try to install the package again it says, that it i already installed. But it appears not in the list on the left side and my progam is not working.
the node says that the definition for the block is not loaded. What can i do? Any Idea?
Thanks in avance!
Hi @einar.kretzler is it in 2025 ? if so you can try ootb polycurve by grouped curves.
also isnt that a 22 version ?
No it is revit 2023
So you mean there is a 2023 version that i can install?
Thanks a lot. It should be deinstalled before. How can i deinstall those package? The automatic deinstallation when i select the 2023 version seems not to work
Thanks a lot for your help.
It seems now to work, but how can i deinstall packages?
Usually requires a restart of dynamo and or revit I think ![]()
yeah as @Kai say, but guess your ironpackage could be updated as well try 2.7 version 2.5
2.13 should have the out of the box PolyCurve.ByGroupedCurves as well.
Uninstallation will require restarting Revit
