Hello @Mostafa_El_Ayoubi,
I’m trying to get the skinting-boards by rooms. If i use wall sweeps i find some problems: first, i need to place them in the wall face that faces the room, so as i wrote before, your great node should include the option to choose the inner or outter wall face to place it. The second problem is that walls may run along several rooms and if i don’t want to place skirting-boards in those rooms i’d had to modify the length manually.
Other way to get this is creating “solids by sweep” and “direct shapes”, but it’s no longer possible to get the information by schedules.
If you have any suggestion it will be great.
Thanks in advance.
Rodapié biselado.rfa (280 KB)
