Wall foundations according to lines
Hello everyone !
I’m trying to create wall foundations with dynamo, in the same script which create walls.
The problem is that I can’t choose any kind of wall foundations in dynamo with “Family Types”…
My script :
Any idea ?
Thanks !
A wall foundation is a System Family which is completely dependent of it’s wall. If you can’t find any nodes for it, you’ll have to use a python script with the WallFoundation.Create method. Here is a completely untested mockup to get you started:
# Import List ( ICollection(ElementId) = List[ElementId]() )
clr.AddReference('System')
# Import Revit API
clr.AddReference('RevitAPI')
# Input
wall = UnwrapElement(IN[0])
wallFoundationType = UnwrapElement(IN[1])
 #Make changes to Revit DB in a Transaction
WallFoundation.Create(doc, wallFoundationType.Id, wall.Id)
OUT = 0
Thanks for your answer !
I’m a beginner with the API and I don’t understand how to load the foundation’s family as you said. I’m have wall foundations already loaded in my project.
Do you have any example ?
Thanks,
Pudiste solucionar ?
EDIT MODERATION : TRANSLATION
Were you able to solve ?
Hi @danco111 please use english, please translate your post…but this post here is 6 years old so better create a new and share all your material so far…thanks
