Any component like "stream filter"
halo everyone , i am new in dynamo ,please help
there are 2 results , i would like to set a condition ,like ,if line1 length is > line2 length ,return true ,so i use A part components, or else, return false ,i use B part components, the concept like below picture,
i got a true / false ,now i am missing a component to filter / run the coming set of components
Does dynamo have come components? many thanks
maybe “if” can solve ?
How about this?
@_vijay we still need a component to trigger different action
Could you give sample example with expected solution?
So that i can try!
i find a similar question
seems that post has the solution. It does not help you?
yes ,it solved , i find it few minutes ago ,thank you for your time
Clockwork package
