Angular Dimension in Dynamo
Hello, I have a problem I can’t seem to solve. I need to add corner dimensions to the nested elements of my parent family. The issue is that I need to add these corner dimensions to the assembly views I’ve created. I wrote a Python script that does all of this, BUT only on sections and plans—not on assembly views. If you have other suggestions on how to solve this problem, I’d love to hear them. Thanks!
Hi @BohdanShevchenko ,
It is basically impossible to help you out if you don’t share any images, files, code, etc. that you already have. Would you mind sharing some sample files, including maybe an image/ sketch of what you need as output ?
