Library for Families in Project
I am trying to extract all different types of families in a revit project;
Then put one single copy of each type of family within a set distance from each other.
I have been trying with packages, and even found a way for walls, but i am trying to do this for all family types.
I would be really glad if you could help!
Thanks!
Hello I did that partially, the difficultly is that you must know how is the placement of family, some are hosted or need a work plane so this ones cannot be placed like the others that are non hosted or juat need a point in a 3d view to be placed
Thank you for your effort and time. Could you share what you have worked on? I also found a way which works for some families but am having issues with some other family types such as glazing which needs curtain systems and am trying to find a workaround.
