All elements of category in active view
Morning from NZ all. I’m either having a brain fart or I’m still just an idiot at dynamo. Made a script to rename some areas but i only want to rename the areas in the active view window. I cant seem to figure out how to do that right now though. Any help?
damn thought this would have worked
works for me just fine:
Make sure you got a proper view. I recommend using the OOTB nodes instead of Clockwork for this.
Thanks @Konrad_K_Sobon. Do you know how i get it to work for a Area Plan view?
well you are trying to grab it from a view that is not supported. Dynamo doesn’t wrap Area Plans yet. It looks like you will need to implement a custom solution.
So back to my point, Select.ByCategoryAndView is working fine.
Cheers!
damn thats a shame. Feel like its a little doge but just did this
Try the nodes from springs for now:
I suggest you make a wish item on GitHub if you’d like to see area views being supported out of the box
