Hello all,
I am trying to gather all grids in the active view (an Area Plan). My script works fine with Floor plans but fails when the Active view is an Area Plan. Anyone have an Idea?
Similar issue:
Hello all,
Similar issue:
Originally reported here:
And solved here:
So this should work in Dynamo 2.0 ⌠
Hi @Steven
Or else you can just write a few lines of python to get it worked in Dynamo1.3.2
clr.AddReference('RevitAPI')
view = UnwrapElement(IN[0])
coll = FilteredElementCollector(doc, view.Id)
filt = ElementCategoryFilter(BuiltInCategory.OST_Grids)
grids = coll.WherePasses(filt).ToElements()
#Assign your output to the OUT variable
OUT = grids
Thanks Andreas,
I was looking around but could not find anything.
Thanks Kulkul,
That worked perfectly.
@Steven Please mark the post as solved. Youâre welcome!
Sorry I thought I clicked it.
The equivalent node in springs is called âCollector.ElementsInViewâ
Will this ever be solved for dynamo 1.3?
