Family: add level information
Unable to use FamilyInstance.ByPointAndLevel (Bug) I use the “Family Instance By Point in Transaction” node to create a family.
The problem is that the level and host parameter are not created in the family (see image)
I can not add the parameter with “Element.GetParameterValueByName”.
An idea ?
**** French
Ne pouvant pas utiliser FamilyInstance.ByPointAndLevel (Bug) j’utilise le nœud “Family Instance By point in Transaction” pour créer une famille.
Le problème c’est que le paramètre niveau et hôte ne sont pas crées dans la famille (voir image)
Je n’arrive pas à ajouter le paramètre avec “Element.GetParameterValueByName”.
Une idée ?
Hi @Alain_Hamel
Could you please share with us rvt and dyn file so that it will be easy for others to solve your issue.
May be @Mostafa_El_Ayoubi put some weigh on this since he knows french :slight_smile:
Thank you for your time.
Attached is the link to download the RVT + Dynamo file
It is a project with central file.
Usage: Open central file Electricite2.rvt
With Dynamo select the link Central file Hydraulique2.rvt
The application must place 4 families above the families of the file Hydraulique2
http://www.sendbox.fr/7d15e6fb61ee0b54/Fichier_central_Hydraulique2.zip
http://www.sendbox.fr/174c7300ea5e6fa7/Place_Attente_Elec_H_V303.dyn
Hello, Springs could possibly offer a solution with HostedInstance.ByPoints, see here:
Update: node’s limitation:
