in new add. shared parameter. i can not find an input to assign data type. zou can see in picture the new and old one. is there any option to add shared parameter with all related information?
Hello…is that a new node in 25…anyway guess the node add a already created sharedparameter from the txt file…where we create the spectype
This isn’t a new node; I just used Orchid Packs, which include this add- shared parameter. but Exclude Group Types". which was available in earlier versions, I think.
Orchid package isn’t compatible with many other packages and standard tools - best to seek input via the package author directly at the github.
has @GavinNicholls provided any update script or plugin to " [Add Shared Parameters to multiple Families?
I have a working script with the Orchid nodes.
Can share when i am at work again (tomorrow).
PS
For Revit 2024.
Yep!
AddParametersToFamily.dyn (30.7 KB)
I get (read) my Parameters and Parameter Groups from an Excel file.
This is only for a singel Family Document.
I use(d) Orchid Package.
Hi @bvs1982 does these nodes create parameters to txt files as well with the same node ?..i like split it in 2 parts first create for txt file and then add to the parameter think its more flexible, but probably just me
;)…but guess many ways it can be done…
No idea ![]()
For context.
I used our Shared Parameter File to make an Excel file with different
Work Sheets. In the Excel file i then have different Work Sheets for different Revit Family Categories as not all Categoires need the same Parameters (in my case).
I think so too
arhhh, thanks ![]()
Thank you for sharing the data. I’m having an issue with the nodes I marked in red. The second ones, Parametrs.BIpGbzyname are always invalid, and for the left one, Parameter.GrouptypIdByName works when i Give Parameter group. and when I set it on the Group Type, the result is 0. However, I believe we need to use Group Type. I would really appreciate any help!
I believe that might be a language thing if i recall correctly as I hard coded some of those node conversions in english.
Might need to review the Python code and use it as a reference instead of my nodes in those steps.
The problem is that in the new API builtinparametergroups is not used anymore
and how to adjust this so it takes a directory with families…
But I am working with 2024
As i said
For multiple Family Documents i am not sure you can do this with the
node from Orchid. I have something for multiple Famliy Documents
from @GavinNicholls i believe, but didn’t have the chance to look into that.
Also thats was for Revit 2022 or Revit 2023.
from @GavinNicholls i believe. Never got the chance to try it after it.
Also it is for Revit 2022 or Revit 2023.
I still have the .dyns, but not just gonna share them unless
@GavinNicholls is okay with it.
Also won’t be able to answer any question you might have about them.
then that is the issue crumple doesn’t work any more in 2025 because of the BuiltInParameterGroup
