Hello, I´m having some issues trying to add shared parameters to multiple families at the same time using Orchid. It works fine for the first item of the Directory Path, but the other documents show no changes in their shared parameters. I don´t know if I´m doing something wrong with the levels at the “SharedParameter.Add” node or what is the problem.
Welcome to the forum!
Can you share the error of the node?
I haven’t used this node before but it might be worth asking…Should the “Read as strings” on your Data.ImportExcel node be set to true?
Ignore if stupid question.
which version are you using for Revit, Dynamo and Orchid package?
Hi there!
I have identical problem like @arq.molinaleone. My shared parameters are only added to the first file in the folder. All the rest is open and saved but nothing is changed in them. Have you found a solution?
Drop the levels by 1 (2 to 1, 1 to no levels). After i made this tutorial the node was changed by the author i think. Longest lacing also.
