Add shared parameter to project not working for Type parameters
Hi everyone,
I hope you can help me to figure out a solution for the following issue:
I got the AddSharedParameterToProject working, the only issue I have found is regarding the Instance/Type (True/False) definition:
  • When I set Instance=True: I get my parameter defined as Instance with values are aligned per group type
  • When I set Instance=False: I get anyway my parameter as Instance but with values can vary by group instance
The problem is that I would like to define them as Type parameters, not Instance.
Any ideas? I hope you can help me :slight_smile:
I am using Dynamo 1.1 and Revit 2016
Thanks!
Rodrigo
p.s. @Kulkul this is my issue, thanks for the cooperation! :slight_smile:
Hi @Rodrigo
Give me sometime i will look at your issue.
Change 1 if you need Instance and 0 for Type.
Still not working, same solution as image and I just add “instance parameters”.
Any suggestion @Kulkul ??
Thank you mate.
@alejandro.daras Could please start a new topic with images/files of your attempts and errors expanded. Thanks :slight_smile:
