I can create almost all types of parameters. Except the Familytype (needed if you want to change nested family with parameters) Is there a way to do it?
Thanks in advance
![Capture|690x452]Hi Jan Willem,
somebody explained me this is impossible in Revit.
A reach-around would be to have all the instances in place, and then manage it by as many yes / no parameters as there are families whose presence you want to manage.
So I keep an eye on this tread…
Hi Willem
Thanks for the reply, i disagree. In revit it is possible i try to make it in dynamo. I have to do this often.
My working methode:
Greetings Jan-Willem
Use Parameter Types node and select “FamilyTypes”
Form with package? or in de project environment.
I am in the family…
It is a built-in node. In Dropdown menu you should select “FamilyType”
After that you should set the parameter value with that family types.
Do you have an example? I really do not get.
Al list of the family types? Tomorrow i try again.
