Add plugins to Revit using Dynamo
Hello everyone, I would like to use Dynamo to create an application on the Revit ribbon that can be used to run my dyn files, and I can input parameters for the application. It’s like a custom node, but this node can be called directly without using dynamo.
At present, I know that Dynamo player can achieve similar functions, but it seems that the player can only run and cannot accept any parameters.
May I ask if you can provide me with some advice? Thank you for any suggestions!!
Also, does NonicaTab seem to be able to? Has anyone tried something similar before?
Hey @22112079 Please go through this thread Here :point_left:, I’m sure you’ll get all the anwers you looking for.
Regards,
BM
or you could try orkestra or Pyrevit
