I would like to use Dynamo to add images to the Manage Images and insert the added images into the parameter “Type Image”.
I could not add an image by connecting the “File Path” node to the “Document.ImportImage” node in Orchid.
Also, when I tried to insert an image into the parameter “Type Image” in the “Element.SetParameterByName” node, I could not insert it because it is a type parameter.
There are many similar topics, but I have not found a solution!
I would appreciate any information you may have.
Environment
Revit:2019.2.1.1
Dynamo:1.3.4.6666
