Not sure if this could be possible.
I would like to create a new sub-category in a detail item family through Dynamo. I have about 400 detail items and I want to create a standard set of sub-categories.
I have never tried it (but will try if and when Iāll have spare time) but if you have some python knowledge you could try and look at this:
Once you manage to get it working on one family you should implement it to work on multiple families, something like this:
You could also apply a material and automatically place certain elements (if correctly selected) in this new subcategory.
I copied the code from the first link in my previous post:
# Import Element wrapper extension methods
# Import geometry conversion extension methods
app = uiapp.Application
# Import RevitAPI
clr.AddReference("RevitAPI")
newsubs=IN[0]
for newsub in newsubs:
#create new sucategory
fam_subcat = doc.Settings.Categories.NewSubcategory(doc.OwnerFamily.FamilyCategory, newsub)
#assign the mataterial(fam_mat.Id) to the subcategory
#fam_subcat.Material = famdoc.GetElement(fam_mat.Id)
#assign the subcategory to the element (s2)
#s2.Subcategory = fam_subcat
@GregX
Thank you for all the information.
I have a good understanding of how it works but Iām still learning python and the API.
I tryied to set it up and I got this error:
Also, how would I go about running the script in all 400+ families?
Thank you for all your help.
Hi @gbardales,
Not to hijack @GregXās answer, but something went wrong in the formatting.
Iāve seen this happend a couple of times now where double quotation marks gets changed to " like here:
See if this works:
# Import RevitAPI
clr.AddReference('RevitAPI')
newsubs=IN[0]
Thanks, I noticed that if I just ctrlc ctrlv pythone code on the forum it gets all messy. Instead I have to paste it āas textāā¦
No probs mate. Are you going to edit the formatting, so that @gbardales can set your post as the solved post?
Iāll retract mine then so people wont get confused
@GregX
@MartinSpence
The script works and creates all the subcategories in the family that I have open.
How would I go about running the script to the multiple families in an RVT project?
thank you
If you google ārevit dynamo add parameters to familiesā you can get some interesting results (even if their goal is a bit different).
Right now I canāt write a graph but this might help:
I think you can edit the families in the project, but for testing purposes I would first save all the failies to a directory (save as/library/families), then in a dynamo graph input a directory, get all the content (OOTB nodes I think, or DanEdu, now Orchid), open the docuents in background (rhythm nodes i think), run my python script (connected to the open.Document node), then close and save the file to your folder.
There surely is a way to do it directly from the project but I still have to try it. I did something similar in this thread but I should edit the code a bit to make it work in your case
I have been trying the nodes that @erfajo mention. They work great and there is a lot of things that I could do with them.
But I been having problems finishing the script, I posted what I been working on.
I have been getting all the families from the RVT file and try to create a set of subcategories and load family back in. Any help with the script will be appreciated.
clr.AddReference(āRevitAPIā)
from Autodesk.Revit.DB import*clr.AddReference(āRevitServicesā)
app = uiapp.Application#log builder, only for testing
#log =#input assigned the IN variable
docs = IN[0]
subcat = IN[1]
fam_subcat =#wrap input inside a list (if not a list)
if not isinstance(docs, list): docs = [docs]
if not isinstance(subcat, list): subcat = [subcat]#default document set to DocumentManager.Instance.CurrentDBDocument
if docs[0] == āCurrent.Documentā:
docs = [DocumentManager.Instance.CurrentDBDocument]
else: pass#core data processing
for doc in docs:
try:
fam_subcat = doc.Settings.Categories.NewSubcategory(doc.OwnerFamily.FamilyCategory, subcat)#assign the mataterial(fam_mat.Id) to the subcategory #fam_subcat.Material = famdoc.GetElement(fam_mat.Id)except: pass
#fam_subcat.Material = famdoc.GetElement(fam_mat.Id)#assign the subcategory to the element (s2)
TransactionManager.Instance.TransactionTaskDone()OUT = docs
Sorry right now I canāt test your script. What happens when you run it? Does it load the familly or not? The only difference I see with the preiovus scripts is that you do not close the families once they are loaded, but I do not think this is the main issue
I was able to make it work from directly from the RVT file and external families but I can only run it with only one family. I also try to put it inside of a node to use the lacing but it only works for the first item and the rest are nulls.
Is there anything I can change in the code to make it work? or can you point me in the right direction?
# Import RevitAPI
newsubs=IN[0]
famdoc=IN[1]
TransactionManager.Instance.EnsureInTransaction(famdoc)
fam_subcat = famdoc.Settings.Categories.NewSubcategory(famdoc.OwnerFamily.FamilyCategory, newsub)
OUT = famdoc
Thanks for the guiding.
