I’m trying to grab a list of subcategories from another family document, but it’s failing to wrap the custom subcategories for some reason. Does anyone know why, or what other method I should use perhaps?
It works for custom subcategories in the same document (as evidenced by the clockwork node Category.Subcategories
), and it works for built-in subcategories in another family document, but not for custom ones.
Here’s my basic setup:
My python node basically works the same as part of the Genius Loci node Family Get SubCategory
dealing with family documents, but without the exception handling.
clr.AddReference("RevitAPI")
famDocs = UnwrapElement(IN[0]) if isinstance(IN[0],list) else [UnwrapElement(IN[0])]
outlist = []
for famDoc in famDocs:
if isinstance(famDoc,Document):
subcats = famDoc.OwnerFamily.FamilyCategory.SubCategories
subcatselems = [Revit.Elements.Category.ById(subcat.Id.IntegerValue) for subcat in subcats]
outlist.append(subcatselems)
else: pass
OUT = outlist
If I don’t try to Revit.Elements.Category.ById
the subcategories and just output them unwrapped, it works fine, but that’s not very useful within dynamo.
