but…
When i create a new Revit file without using a Template and not Link a IFC file but Open it instead, a Shared Parameter File is also created.
If i then go back to my file with a Linked IFC file in it, and add the Shared Parameters as Project Parameters, i can create Filters and Color overrides based on those Parameters (Like IfcZoneName or IfcName and others).
question is:
How to do it using Dynamo
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
def Add_IFC_Filter(lst_guid, filterName = "IFC_Filter"):
Creates or updates an IFC filter based on the provided list of IFC type GUIDs.
Parameters:
lst_guid (list): List of IFC type GUIDs to include in the filter.
filterName (str, optional): Name of the IFC filter. Default is "IFC_Filter".
Returns:
ParameterFilterElement: The created or updated IFC filter.
iListBic = List[ElementId]([category.Id])
subFilterA = List[ElementFilter]()
# set first filter
subrules = List[FilterRule]()
for guid in lst_guid:
subrules.Add(ParameterFilterRuleFactory.CreateEqualsRule(ElementId(BuiltInParameter.IFC_TYPE_GUID), guid, True))
for filterRule in subrules:
subFilterA.Add(ElementParameterFilter(filterRule))
subFilterA = LogicalOrFilter(subFilterA)
filterFunc = System.Predicate[System.Object](lambda x : x.Name == filterName)
paraFilter = List[DB.Element](FilteredElementCollector(doc).OfClass(ParameterFilterElement).ToElements()).Find(filterFunc)
if paraFilter is not None:
paraFilter.ClearRules()
paraFilter.SetElementFilter(subFilterA)
paraFilter = ParameterFilterElement.Create(doc, filterName, iListBic, subFilterA)
return paraFilter
def create_Override():
Creates an OverrideGraphicSettings object with specific surface foreground pattern and color.
Returns:
OverrideGraphicSettings: The created OverrideGraphicSettings object.
solidFilter = System.Predicate[System.Object](lambda x : x.GetFillPattern().IsSolidFill)
solidpatern = List[DB.Element](FilteredElementCollector(doc).OfClass(FillPatternElement).ToElements()).Find(solidFilter)
ovg = OverrideGraphicSettings()
ovg.SetSurfaceForegroundPatternColor(DB.Color(0,0,255))
ovg.SetSurfaceForegroundPatternId(solidpatern.Id)
return ovg
toList = lambda x : x if hasattr(x, '__iter__') else [x]
lst_guid = toList(IN[0])
category = UnwrapElement(IN[1])
view = UnwrapElement(IN[2])
ifcfilter = Add_IFC_Filter(lst_guid)
ovg = create_Override()
if view.AreGraphicsOverridesAllowed():
if not view.IsFilterApplied(ifcfilter.Id):
view.AddFilter(ifcfilter.Id)
view.SetFilterOverrides(ifcfilter.Id, ovg)
OUT = ifcfilter
Maybe asking too much, runtime <> file size?
Sorry
I had it sketch out like this btw
-read xml
-find param
-copy
write as UTF8 txt file to create a Shared Parameter file
