I’m new to Dynamo and had been working in 0.6.3 and noticed when I updated a bunch of nodes are missing and some of my scripts I cant seem to get to work. I had been using the “Equal Distance XYZ’s on Curve” node and the “Lines Through Points” node.
Hi Jesse, there is a document about the migration from 0.6.3 to 0.7: https://github.com/DynamoDS/Dynamo/wiki/0.6.3-Upgrade-to-0.7-version. 0.7 has its own geometry library, so for these two nodes, please try “Curve.PointAtParameter” and “NurbsCurve.ByPoints” or “PolyCurve.ByPoints” nodes.
The files which you had created in 0.6.3, should be migrated to 0.7.1 when you open them in 0.7.1.
If you see any of the nodes are not getting migrated and showing as Deprecated or UnResolved then you can list out those reply back, we will provide you more information on that.
