Yes/No parameter create ScheduleFilterBy
Hi
I want create ScheduleFilter of YesNo Parameter,
I tried with 1 and True but return error.
Can be fix this.
Thank Advance!!!
Hi @manhgt214 try take a look on this post here from Cyril…
Thank you so much!
By the way, can be create Schedule with Multiple Categories in 1 view.
I founed below, Thank you!
clr.AddReference('RevitAPI')
#revit_xyz = XYZ()
#revit_point = Point.Create(revit_xyz)
#revit_xyz.ToPoint() = revit_point.ToProtoType()# Both need library Revit.GeometryConversion
#import os
#PathOfModule = os.path.abspath(a_module.__file__)#Get path of module example (Revit.__file__)
names = IN[0]
schedule = []
id = ElementId.InvalidElementId
for i in names:
	#newSchedule = ViewSchedule.CreateSchedule(doc,id)
	newSchedule = ViewSchedule.CreateMaterialTakeoff(doc,id)
	newSchedule.Name = i
	schedule.append(newSchedule)
OUT = schedule
