Yes no Parameter in Schedule filter
Hi All
Can abny one help me here please to set parameter value in schedule filter via dynamo.
Been on it all day and keep getting error tried all i found but without a joy.
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
Views = IN[0]
FieldId = IN[1]
Filters = list()
for Id in FieldId:
F = ScheduleFilter( ScheduleFieldId( Id ),ScheduleFilterType.NotEqual)
Filters.append(F)
TransactionManager.Instance.EnsureInTransaction( doc )
 for View, Filter in zip( Views, Filters):
 ( UnwrapElement( View ).Definition ).InsertFilter( Filter,0 )
OUT = IN[0]
Working with Schedules fields is a bit of track game in the Revit API :grin:
try this (this script replace a exist boolean value filter)
# Import RevitAPI
toDoList = lambda x : x if hasattr(x, '__iter__') else [x]
lstView = toDoList(UnwrapElement(IN[0]))
nameParaFilter = IN[1]
valueBool = IN[2]
def findFilter(paraName, scheduleDef):
	filterCount = scheduleDef.GetFilterCount()
	for idx in range(filterCount):
		schedFilter = scheduleDef.GetFilter(idx)
		field_Id = schedFilter.FieldId
		field = scheduleDef.GetField(field_Id)
		if field.GetName() == paraName:
			return idx, schedFilter
	return None, None
for v in lstView:
	if v.ViewType == ViewType.Schedule:
		scheduleDef = v.Definition
		idx, schedFilter = findFilter(nameParaFilter, scheduleDef)
		if idx is not None:
			if valueBool:
				schedFilter.SetValue(1)
				schedFilter.SetValue(0)
			scheduleDef.SetFilter(idx, schedFilter)
OUT = lstView
Hi Thanks for your time.
my goal is to create filter with value as per screen shot. Is that possible??
Regards
Hi what do you mean by "per screenshot " ?
Hi thanks for your time again.
I want to create filter with dynamo. Not get filter from schedule and then change it.
I want to be able to create filter field using Yes/No parameters
hello
here is the script completed with the addition of a method for creating a filter
Updated code here
# Import RevitAPI
valueBool = IN[2]
	return None, None
def createFilter(paraName, scheduleDef):
	#sub foncion
	def checkField(fieldToAdd):
		fieldIds = scheduleDef.GetFieldOrder()
		for fieldId in fieldIds:
			if scheduleDef.GetField(fieldId).GetSchedulableField() == fieldToAdd:
				return fieldId
		return None
	#main function
	fieldToAdd = None
	#get GetSchedulableField by Name
	lstAvailbleField = scheduleDef.GetSchedulableFields()
	for schField in lstAvailbleField:
		if schField.GetName(doc) == paraName:
			fieldToAdd = schField
			break
	#check if field is already added and find the corresponding fieldId
	fieldId = checkField(fieldToAdd)
	if fieldId is not None:
		return fieldId
		#if not found add the corresponding field
		scheduleDef.AddField(ScheduleFieldType.Instance, fieldToAdd.ParameterId )
		doc.Regenerate()
		#then return the corresponding fieldId
		return checkField(fieldToAdd)
for v in lstView:
		if idx is not None:
			if valueBool:
			fieldId = createFilter(nameParaFilter, scheduleDef)
			if valueBool:
				newSchFilter = ScheduleFilter(fieldId, ScheduleFilterType.Equal, 1)
				newSchFilter = ScheduleFilter(fieldId, ScheduleFilterType.Equal, 0)
			scheduleDef.AddFilter(newSchFilter)
OUT = lstView
Top man
Thanks!!!
Out of curiosity, can a schedule field be adjusted with a script similar to this. Say the filter is XXXX.YYY.ZZZ, and you want to change XXXX to AAAA, while leaving the .YYY.ZZZ untouched? I am just starting to generate the basics of this and just want to know if it is feasible in your opinion at least.
Hello @Mike.Meyers
It should be possible, better to start a new topic with screenshots for better understanding
Thank you sir, let me give it some due diligence first before I open a thread. I am inexperienced enough I just wanted to make sure it was possible before spending too much time attempting it.
Hello!
I have a problem with a same type of filter but i do not manage Python. I’ve try your scrypt but i don’t know how to adapt it for my situation. Can you help me, please?
PS. Filter ID Appartment work if i start two times dynamo
Hi @k.khisamova ,
try to add a Transaction.End node
Note:
It’s better to start a new topic, than digging up an old
@c.poupin ,
Sorry, I don’t know how to start it :slight_smile:
Unforchenatly it doesn’t work
Tableau par lgt.dyn (343.4 KB)
can you share a simple Rvt file for test ?
Hello!
Here you find Simple RVT file (2022) for test
SIMPLE RVT.rvt (7.7 MB)
@k.khisamova
here is the fixed code
[image]
# Import RevitAPI
valueBool = IN[2]
	return None, None
	#sub foncion
			if scheduleDef.GetField(fieldId).HasSchedulableField:
					return fieldId
		return None
	#main function
	fieldToAdd = None
			break
		return fieldId
		doc.Regenerate()
for v in lstView:
		if idx is not None:
			if valueBool:
			if valueBool:
OUT = lstView
@c.poupin ,
Thank you so much! its perfect! :blush:
